Tricky991
- Oct 6, 2014
- Texas
- Aaron
- C10
Hey everyone, I am having some trouble with my engine. The other day I replaced the fuel pump, I am not even sure how the old one was even pumping the arm barely moved. Replaced with new one, and after I got it in went for a test drive.
Well everything went fine till I floored it. It picked up fine but right before it shifted the engine lost power like I just ran outta fuel. I let out the throttle and slowly eased back in and it was working fine again.
Well it only did that a few more times at WOT, but then it started bucking. But after a week it stopped doing that. And then it came back worse, as the engine got into higher RPMs no power at all couldn't do anything over half throttle. Got to the point were the 2nd set of barrels wouldn't open. Which I would think was vacuum problems?
And as of yesterday no power at all. Could barely make 30mph. It gets worse as the engine warms up. Like cold it has a little power and at normal temps no power. And it is running hotter then normal.
And it started having a knocking sound. coming from either the front or front passenger side of the engine. I pulled the fuel pump thinking it was something with that messed up. But the pump and push rod look fine. Even started it for a sec with it off and still had the knock.
What do you guys think? Hopefully something simple lol
