- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
So you can tell by comparing pics, there is a definate difference in 3/4 and 1 ton rear axle mounting. Not only are the shocks on the 1 ton swing in opposite directions, they are also inboard of the frame instead of outboard of the frame. This is likely why the 3/4 and 1/2 tons put the springs further from the frame, is to make room for the shock mounts to the frame.
So that settles it. Even the SRW 3/4 ton Crew Cabs have 1 ton set up rear axles. Which kinda hurts you in a way. 3/4 ton axles are much more common and easier to find. But why would you want to change it?
