3/4 ton vs 1ton
So you can tell by comparing pics, there is a definate difference in 3/4 and 1 ton rear axle mounting. Not only are the shocks on the 1 ton swing in opposite directions, they are also inboard of the frame instead of outboard of the frame. This is likely why the 3/4 and 1/2 tons put the springs further from the frame, is to make room for the shock mounts to the frame.
So that settles it. Even the SRW 3/4 ton Crew Cabs have 1 ton set up rear axles. Which kinda hurts you in a way. 3/4 ton axles are much more common and easier to find. But why would you want to change it?
fowjacob
Lubbock,TX
c3500
383 Stroker
Not planing on changing it just wanted the info mostly and to help deside on a Dana 44 or Dana 60 on my 4x4 swap
Thanks for the awesome info that's been bugging me for about a week
3/4 ton truck with a 1ton frame and rear axle set up hmmm weird but I kinda like it
If you can do it, by all means, do the Dana 60. If funds permit, I'd be all over the Dana 60.
BTW, those spring hangers look like they're aftermarket lowering hangers. Is your Crew Cab lowered at all?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the 3/4 ton crew cabs used the 1 ton frame and the 1 ton spring hangers
3/4 ton crew would be the same axle as a 1 ton crew single rear wheel same perch width and shock mounts
they may have the small drum brakes or the big ones depends what options it had
the crew cabs used the 1 ton frame and axles weather it was 3/4 or 1 ton
only difference would be size of the rear brakes and spring packs more load capacity with 1 ton
this only applies to crew cabs not single cabs
and all the 3/4 ton crews i have seen were 2 wheel drive not saying they did not make a 3/4 ton 4x4 crew cab but i have never seen one
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
****** must have me blocked, I told him how to measure the perches.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
3/4 ton hanger bolted back to back with a 1 ton hanger
and if you ever need to put a 3/4 ton axle in a 1 ton i found a easy way to change spring hangers i did it to my 4x4 crew. details are in my build thread
fowjacob
Lubbock,TX
c3500
383 Stroker
Well I have noticed its pretty level for not have the diesel in it anymore so might
I've seen 3/4 ton 4x4 crew cabs, they were all '76 or older and had a D44 front axle. I don't know if they had the 1 ton frame and rear suspension.
fowjacob
Lubbock,TX
c3500
383 Stroker
I'm thinking it has the big drums. Almost fill in the rim
fowjacob
Lubbock,TX
c3500
383 Stroker
Where are you seeing aftermarket lowing hangers btw I'm not seeing them
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
he is probobly got the 4x4 spring hangers in his mind those are stock 2 wheel drive hangers the 4x4 ones sit lower and lift the truck up more for the 4x4
and ya i would say those are the big 1 ton brakes
fowjacob
Lubbock,TX
c3500
383 Stroker
Thanks guys for all the helpful info maybe ill be able to find a 4x4 Dana 60 donor before the summer so I can start my 4x4 swap. If I can't find a Dana 60 for the right price just might have to go with the 44 but if that's what I have to do I guess it would make it cheaper
aaron06
