1982 k10 to newer power train
munrom
Canada
sierra k10
Hello, im looking at getting 1982 k10 that the engine is pretty much wore out and the transmission is on its last legs but the body is still in good condition. I have a 1994 k1500 that the body is shot i was just wondering if the engine and transmission and tcase will all fit into the truck and what all i would need to come with it, ive tried google searching and really couldnt find anything that i was looking for but maybe i wasnt searching for the right things.
Thanks for any advice.
yevgenievich
Viktor
sad
very sad
less sad
Engne and transmission will, but the t case would need to be swapped to a passenger drop with vss if using 94 transmission. Or just swap engine only.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I'm gonna guess that the truck you're looking at is a 350/TH350/NP205 combo and yours is a 350/4L60E/NP241. This is just an assumption, but it would help if you could confirm or correct these specs. You would need the complete harness out of the newer TBI truck to control the engine sensors and transmission, but that shouldn't be a big deal since its your truck. I don't really see a way to make the transfer cases you have work. The cheapest and easiest thing to do, in my opinion would be to get a 1990-91 square body passenger side drop t-case so it'll be VSS ready and match the output on the 4L60E without trying to make the NP205 VSS compatible, which there is a company that does that, I believe. I'm not sure about driveshaft and crossmember concerns.
ceyman72
