14 bolt 10.5" rear disc conversion
Kid26jr
Ellsinore, MO
Lane
I'm new to the forum and looked around but didn't see anything on it. I have an k10 the has been k20 swapped. It has a Dana 44 in front and a 14 bolt in the back. Wanting to switch to disc in the rear any suggestions?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I did this last year on my 98 K2500, used a kit from Lugnut4x4, had the brackets, lines, calipers, everything for cheaper than I could buy them for.
For a FF like yours, there are tons of weld on brackets, so you could go that route with a squarebody front caliper and save a little.
http://lugnut4x4.com/product-category/rear/
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
That's a great price. I bought the brackets Offroad Design makes, they're heavy-duty but expensive, and that's all you get. (http://www.offroaddesign.com/catalog/14FFdisckit.htm) Brackets, spacers and mounting bolts. Had to buy calipers which I got K10 fronts but I hear K20 fronts have bigger pistons. I had a couple spare calipers laying around and a lifetime warranty receipt so I just swapped them out. Had to buy front rubber lines for K10 and figure out how to mount them. I used large washers welded to the leaf spring top plate. Also got a cheap adjustable proportion valve from Jegs but I've read you can modify the stock proportion valve for more rear pressure. I've also read a lot about people trying corvette master cylinders for more fluid displacement from its bigger piston but my stock mc and prop valve works fine, I haven't even needed to adjust the Jegs valve from the neutral (middle) setting. By the way if your state requires a park brake to be street legal you may want to look into using Cadillac calipers and rotors (I forget what year).
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I got a extra set of K20s not gonna guarantee thier condition but they are good enough for cores.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Check out Cut Bro's on Facebook. They offer a kit to bolt later 14-bolt AAM 10.5" brakes onto the older 14 bolts. These use the drum-in-rotor e-brake w/ stock 2500HD calipers, if I recall right:
Affende
ColoRADo
Affende
83 and 84
C1500 and K3500 3+3
250 and 454
I just looked those up. i have been wanting a disc brake setup w/ e-brake for my 3+3 but i didnt like the eldo calipers (i think they are too small for a loaded 1 ton).
Cut bro's sell just the adapter plate and then you source all the parts on your own. the parts are actually fairly inexpensive. $376 for parts from rock auto ($60 of that is core charges) .... but the $200 price tag for the custom brackets is a bit hard to swallow.
so all told you would be in for $600 with shipping costs and tax. not terrible, but not cheap.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Yeah, it's definitely not cheap, but it's the best option (in my useless opinion :p ), short of finding a late model axle, but then you get into modifying the spring pads and shock mounts and etc.
Affende
ColoRADo
Affende
83 and 84
C1500 and K3500 3+3
250 and 454
I agree. After looking at many different options over years, for a daily driven street rig that has to be inspected or an owner that needs, or wants, to have an e-brake .... its definitely the best option.
and $600, all in all, isn't a lot of money for what you are getting. especially since it adapts one ton brakes rather than 3/4 ton brakes.
all of the essential parts they use can be sourced from a 2004-2010 gmc sierra 3500. I would trust it for sure on my 3+3.
vkh
Western Montana
Var
C2500
I really like that solution, I'll have to see if I can make room in my budget sooner than later for a disc conversion. The parking brake has been making me hold off for some time now.
dougbert
5535 feet in Utah Mountains
doug
K1500/nv4500/np241c/33x12.50x16/4.10 Gears 14BFF
5.3L - 2002 Silverado, rebuilt top end, long tube headers
I am going the Cut Bros. route on my 14bff that I will install into my K1500 which currently has a 12-bolt rear. Documented in my build thread at http://www.gmsquarebody.com/threads...in-with-a-2002-5-3l.14428/page-37#post-378936
I document following their instructions AND points where they failed to document properly
I have provided feedback to them on those issues.
There I posted all the parts costs.
summary total here:
$662 in parts and lathe labor
$160 for the axle from a friend
$200 for the Cut Bros. adapter
I liked this recipe to do this since it did NOT require cutting of the axle flange nor welding the caliper bracket. It uses GM.ACDelco parts, save for the pair of adapters. AND it give a parking brake.
Lookup Cut Bros. on Facebook
link to their mostly good instructions: https://drive.google.com/file/d/0B1Bfrv5SpptudmQ3Yk5SdWgzOFl0MlBQdWIyZy1FcGhaZEMw/view
87R10_Cruising
