12" lift question
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
Just wanting to know if when I do my 12" suspension lift on my truck if I will need to divorce my t-case from the trans do help my front driveshaft angle. Thanks!
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
what tranny and t case
i am putting a divorced 205 in my truck with a 12'' lift just cause i have a 2 wheel drive 400 and the divorced 205 already
my buddy has 14'' on his truck running a 400/205 married so it can be done with married units
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
I have a 700r4 unfortunately and I believe the t-case is a 205. Are there any advantages to divorcing them other than front shaft angle?
Very Very rare to see a NP205 behind a 700r4. If ever.
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
Sorry I just went out and looked and its a 208 with a letter C after it...anybody know what that's about?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
700r4 is the is the longest tranny that came in a square with a 208 you would have the best front drive shaft angle possable with a stock tranny and t case
the rear slip yoke would be the only bad thing with your combo
you can get a clocking ring and clock your t case down for a better front shaft angle
http://diy4x.com/cart/index.php?route=product/product&path=18&product_id=64
what size tire are you running and how do you plan to use the truck
if you are running big tires and use it off road you might want to get a stronger tranny and t case
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
Right now the truck has 31x10.50 but it will have a 12" lift with 38's or 40's soon I hope and mainly be a pavement pounder on Saturday evenings. Maybe hit a few trails... Not really into mud and rocks lol
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
light use like that it should hold up ok
i think i would try the 700r4 208 in stock form if you have problems clock it down to help the front shaft angle
maybe think about 10'' lift instead
K10 DELUXE
Missouri
K10 custom deluxe
Bone stock 350
Is it easy to install? Do I need to modify my crossmember?
duckboy_17
