wiring of the wiper switch to the motor
ditzr
Pontypool, Ontario
Rod
C15
thank you in advance for your help with my little issue.. trying to save myself some time..
I have a 75 GMC C15 and i am doing a complete wire harness change.. i have been moving connectors over from the old harness to the new harness without too much trouble.. but i went ahead and cut out the wiper motor and switch wires from the harness, before i traced them through to each other..
i was hoping that someone here would have a colour code wiring diagram
thank you...
Rod
Iirc, that diagram is posted in the library category.
Even the original GM diagram is not color coded, but they are labeled by the color of the wire. It's also not a separate diagram, it's on at least two pages and has other systems on the same diagram.
ditzr
Pontypool, Ontario
Rod
C15
Thx Bucket, i did find a set of wire diagrams and they are very helpful.. i think i should be able to figure this out now..
Dons79C10
