Which rear diff fluid do I need for Dana 70HD?
1989 R3500
Oklahoma City
Christian
R3500
I'm getting ready to buy my parts for the rear differential on my 89 Chevy R3500 dually.
Can someone tell me which diff oil is best? I.e 75/90, 75/140 etc.
I'm probably going with Royal purple or Lucas.
Thanks in advance.
Is that a 14 bolt or is it something else? Most manuals say 80w90 unless in Canada (or just coldser climates) but I guess do you have any modifications like locker or posi? Depending on that miht need additives.
nvm i didnt see your title said dana70hd. do you have an owners manual for that year? if so, it should list a fluid viscosity to use, but the spec it suggests will likely be superseded. gl-5 is what mine asks for
088-jpg.11356
this is from 1989 truck manual. 80w-90 GL-5
ali_c20
Austria
Alexander
C20, K5
The important thing is that it's GL5 for high pressures in the hypoid gear setup of the differential. 75w-140 if you use your truck for towing and long distances, but it's double the $ as 80w-90.
gl-4 has the compatibility with bronze/copper in old gearboxes
1989 R3500
Oklahoma City
Christian
R3500
Thanks for the replies. I ordered Amsoils' 80w90 synthetic this afternoon.
thats a lot of fluid, but its a lot of good fluid! Make sure you got a good new breather and tube :)
and if yoiu are going big or go home, id put a cover with a drain and fill plug
twitch1989
