What would be the best course of fixing this exhaust mess?
I know.
I didnt do this by the way.
My thinking: cut out this excess bloat bs, get the the piipes expanded to original OD(?), find a piece of same size between each section, use appropiate BAND exhaust clamps, fix hanger in the front, and then rotate resonator so that it is not gonna catch the ground.
I will then fit it all so the hangers arent stressed, then check for bad leaks and repair(tape needed in one spot), then recommend customer get it welded if harassed by police but not to sink any money into this pile
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
I know.
i agree 100%
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
i'd also probably steer away from the tape and just get it done right, but budgets are budgets
its just a spot hole after the cat the metal isnt rusted out but no matter how we limp it along its not worth a new catback or cat. the thing runs so bad i wouldnt be surprised if the cat is plugged too
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Total exhaust delete, Open manifolds, just duct tape the 02 sensors (if applicable) to the body.
It'll be fineeeeee
:angels2:
Vbb199
Salisbury NC
Vince
I also notice a hole in the floor, JAYSUS things are bad there :(
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
It'll be fineeeeee
:angels2:
hell of a situation you got there. and TECHNICALLY in a non-emission inspection county, as long as the sensors ARE present someway somehow, YOU PASS haha
Vbb199
Salisbury NC
Vince
Oof it'll run SO BAD if theyre getting fresh oxygen though lol
She must not have to do emissions, i'd think they wouldnt pass an exhaust in that state, but i may be mistaken?
we have emissions. but this is for a friends gma.. 2002 pontiac montana. 3.4l v6.not a listener.the cat is still there and so are O2 sensors, I was just gonna patch the hole so the 2nd o2 works
Vbb199
Salisbury NC
Vince
Yeah, you definitely want the secondary o2 working, otherwise it'll cause a rich condition as well, further clogging the cat.
SquareRoot
Sawzall and an LS swap
Looks easy peasy rotate the muffler slide it back 2 inches clamp it and tack it. Cut the forward flange off slip pipe in the front slip pipe in muffler, 2 clamps and 1 hanger. If you can add tacks at each connection so things don't move.
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
depends who inspects it really lol
sybau
