What plugs here?
Olythekid
Nevada
Oli
K20 Suburban
To the left of it is the washer I would guess. My issue is the wippers don't stop, they keep on runing.
Dutch Rutter
Independence, Or
Joshua
I might be wrong here.
I believe those plugs to be related to the washer fluid pump.
If your wipers are not stopping then I would be looking at the actual switch be it on the dash or the column.
Olythekid
Nevada
Oli
K20 Suburban
I'm with you. I have a new switch and new motor. I'm trying to figure out what goes where so i can troubleshoot. The wiring diagram on this web site does not show the same color of wiring.
75Monza
Colville, Washington
K30, K20, K20
Did you have the problem before you installed the new wiper motor? I've had 2 reman units right out the box do that in the past, the park switch inside would not make so keeps on cranking.
CaseyLegg
Spokane, WA
Casey
I had a transistor short out in my pulse wiper control box that kept the wipers going. Recently fixed with a refurbished unit from a user on here gmachinz. Good price too!
If you had the problem before replacing your motor assembly, I would look into that.
Snoots
Roger
Jimmy Sierra
350 w/203
Olythekid
Nevada
Oli
K20 Suburban
Thank you for the input. Casey, I have the 3 position slider control switch, I believe them not to be the pulse type.
Snoots, thank you for the diagram. That H position 3 to 18, do you want me to install a jumper cable? I am just trying to install how it was from the factory, not a 'band aid fix'. If I may be bothersome, would one of you with a similar wiper motor take a picture of what is plugged where?
Mavric16
