What is best gas tank coating?
75Monza
Colville, Washington
K30, K20, K20
Just ordered new tanks for my '80 K30, was wondering what the best coating to put on the tanks would be before I install them?
CSFJ
I would say a good epoxy primer, and the paint color of your choice. These have enough of a tendency to corrode, that for myself, I would avoid anything thick enough that would hide rust if it started underneath said coating.
75Monza
K30, K20, K20
Not even sure if they come with a coating, bought them from Brothers. Since they are going on my plow truck, worried about the seams and the strap areas.
Swims350
Logan WV
none
following I just bought one for my 86 gmc k15, need another.
I was thinking just a clear coat fo rmine I like the silver they are.
Maybe a chassis saver or something?
For the strap areas I alway suse some rubber strips but maybe some chassis saver or something then some rubber?
Doppleganger
OH-MI: Just like it sounds
I'm having mine powder coated....just need to figure what color.
Gotta be stylish.
75Monza
K30, K20, K20
I ordered the strap pad kit for each too, not sure what it is made out of. If it's galvanized, I've heard people having trouble getting paint to stick very long, could be just the type of paint they are using. Hoping they are bare metal, much easier to paint. I do have a quart of cold galvanizing compound I could brush on too.
Dan Miller
K15SG
Indiana
Daniel
K15
I just put one on my K15 .. I used rustoleum 2x black paint
/primer on the top and. Duplicolor rock guard on the bottom. I used a thin rubber mat material cut into strips for my strap pads. Have had good luck with this combo on previous builds
Swims350
Logan WV
none
I think you may be right on the galvinized comment they very well may be and good point, I wonder if a man could use some of that trailer roof coating stuff on one? I know they got that in silver was called cool seal or something?
Hard
