Welding problems
Wilfred
Western Massachusetts
Wil
Blazer
350ci
Millermatic 211 is shorting out. The wire keeps grounding (welding) out to the opening of the wire liner INSIDE the welding unit where the wire feeds into the liner. I am going to replace the ground clamp and wire liner? Anyone have this happen or know the problem and if my new items will fix the issue?
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
You mean inside the case? Under the flap/door where the wire roll is?
Wilfred
Wil
Blazer
350ci
Yes right where it feeds into the weld wire sleeve it balls up into a tiny welded bend/ball that stops the wire from feeding through the sleeve.
Scotty D
Convoy, Ohio
Scott
C10 Bonanza Big10
Sounds like the liner is shorting out to me
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Yup. sounds like the liner is wore out, then shortin out after it all balls up. Assume your tip is clean and the right size?
Wilfred
Wil
Blazer
350ci
So, replaced the liner and the ground and she is still shorting in the same location WTF is wrong with my welder?!?!?!?
75Monza
Colville, Washington
K30, K20, K20
Might check your nozzle and make sure the Teflon liner is still good. Also, want to lay cable out straight and try to feed wire through to gun by hand with tip off, there should be little to no resistance.
Wilfred
Wil
Blazer
350ci
It was the contact at the unit. The 4 or 5 square inches of contact area at the unit was corroded enough to stop current flowing down the line and making it try and go up the wire.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
It's bird nesting right after the last roller?
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
So? You got it sorted out?
dvdswan
Port Orchard, WA
Dave
Good to know. I've got the same welder, I'll have to look at it.
FenderBanger
