U-Joint Conversion
Sherrow74
Missouri
Cole
I have a 1974 k10 and recently swapped in an sm465 and np208 out of an early to mid 8Os truck. The problem im running into is that the 80s driveshaft has a different u-joint than the 74 12 bolt will accept so i was wondering if anybody else has ran into this problem and i was wondering if there was a conversion u-joint for this configuration.
Kiev
Alexandr
U Joint Conversion
Younwi
You will likely need a conversion joint. You can get them at a drive shaft place.
Will have two different sized caps. The 8.8 is a little bigger
