Turbo 400 Yoke Bolt Torque
79ramp
Everett, WA
Aaron
C30
I have been searching on this site and all of the interwebs for the better part of the day and I have had no luck finding the torque for the center bolt on the yoke of my turbo 400. Anyine have this info? Any help is appreciated.
74 Shortbed
All I ever did was use blue Loc-Tite and tightened it with a 1/2" drive ratchet, never had one come loose yet..
I always just went with tight AF with a 1/2 in ratchet by hand, and didn't use any Loc-Tite and never had a problem. A couple drops of blue wouldn't hurt but using red would be way overkill IMO and you'd regret it later on. I rarely use red Loc-Tite.
79ramp
Everett, WA
Aaron
C30
Turns out the bolt was somewhat rounded to begin with so after a while with the torque wrench heading towards 150, I couldn't keep the socket on the bolt and decided that meant it was tight enough :gr_grin:. I now feel better about that strategy, thanks for the advice!
74 Shortbed
Red is "permanent" you need heat to get it off..
Right, I don't use red much. I'll be using it on things like when I cut frame rivets to move my rear spring hangers and use hardened bolts to remount them. I'll be using plenty of red on those threads.
74 Shortbed
Same here, only use it if I know it's never gonna come back off,lol.
