Truck lite 27270c LED upgrade.
Dysco
Wisconsin
Truck lite 27270c:
I picked up some extra cash on a side job. I decided to upgrade my headlights. While I know that there are brighter (jw speaker) i chose to try the truck lites for these reasons. 1. DOT compliment. I don't want to be one of the numerous douchebags that are running off-road lights on the highway. 2. Looks. I wanted something that is at least similar to the stock look. Bug eye, spider eye, and green halo just aren't for my truck. 3. Price. Yes there are cheaper, but truck lite has dropped by almost $100 per headlight in the past 8 months making it competitive with the knock offs. 4. Warranty. While a few headlights are a bit cheaper, most have zero warranty.
The halogens in the truck just weren't cutting it. My drives to hunting and sometimes for work are in the dark on country roads in heavy deer country, exactly like the photos are taken on. As you can see in the pictures, the truck lite, even on dim is brighter than the halogens, especially into the ditch area. The truck lites do have some shadows, which I was aware of prior to purchase. They are not very noticeable when driving, but they are there.
The distance to the weeds at the very end of the road is exactly 96 yards in all pics.
Lastly, absolutely a perfect fit in my 79. Zero adjustments to anything, just plugged in and button up. 15 min max to change.
With each photo I was standing directly between the two headlights with my back touching the pushbar. In order they are halogens dim, halogens bright, truck lite dim, truck lite bright, appearance. I hope this can be helpful for other round eye owners.
eskimomann209
Modesto
Marcus
Well I was just looking at lights since my low beam on the passenger side took a crap on me.
I’ll look into these
Dysco
Wisconsin
The pictures don't really show the real difference.
With the halogens on bright, i could just barely make out the weeds at the end of the road. With the truck lite i could easily see bushes and trees another 40 yards beyond the weeds. That's over 400 feet.
I would expect that the glow from a deer's eye should be much more visible, and hopefully get me to and from where im going with less chance of incident.
Dysco
Wisconsin
I did an "auto correct" on my phone which is closer to what the headlights look like. Both are of high beam. Halogens first, truck lite second.
Glad to answer any questions if I can.
antilla307
Wyoming
Has anyone done the 4x6 Truck-Lite LED in their 4 headlight system? If so, do they mount up correctly or do you have to do any modifications? I'm looking at putting a set in my '85, just curious as to what I may be in for.
78C10BigTen
pennsylvannia
C10 BIG TEN
I have been lookin for a better set of headlights for mine. They definiately are better! What was the total cost? I actually have mine adjusted way annoyingly high right now
Dysco
Wisconsin
I think i figured out most of my shadows in my light pattern. After doing adjustments to the headlights, but the shadow doesn't move, i saw that its my pushbar blocking/reflecting the light as the output is much wider than the halogens so it hits the flat edge on the sides.
As for price, i paid $310 total for 2 headlights a couple months ago.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
I have a set of the Trucklite 5x7 "single" headlights in my 85. They fit the factory headlight bucket with no mods and plugged right into the harness.
antilla307
Wyoming
So, what type of modifications did you do to get your '85 to a single headlight system? I'm new to the square body scene, just trying to educate myself.
1985c20
Torrington, CT
Chuck
Probably nothing. 5x7 Single square headlights were standard from 81-87 the dual/Quad headlights were optional.
antilla307
Wyoming
Thanks for the reply, I'll do a little more research to see if that's a viable option for my truck.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
my 85 is a factory single light truck. If your truck is a factory 4 headlight system, you also have to change the core support. Probably easier to get the 4x6 lights.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
antilla307
Wyoming
Thanks for the info, I'm sticking with the 4 headlights, just trying to talk myself into spending that money!
Will Norton
Nashville TN
Will
K10 Blazer
5.7 350HP
just ordered 2 of the lows and 2 of the high beams in 4x6 for an 84 K5 Blazer. will post how it goes.
mick84
