Towing capacity of '87 1500 2WD 5.7?
Evans Ward
GA
Evans
Sierra Classic 1500
Anyone know what is the max towing capacity for the 1987 1500 series 2 wheel drive with the 5.7 350 TBI engine? Just wondering what I might be able to haul on the bed and/or tow on trailers. Thanks in advance!
jetman
Minnie, AK
Don
I have an '83 k10. With a 3.08 rear gear, it seemed to start to get unhappy if the gross load (truck and trailer) got over 10,000#. Around my property I sometimes "dolly around" 12,000# 5th wheel trailers with no issues.
At the end of the day, maximum load is kind of limited by several things, including but not limited to:
1) Rear gear ratio, bigger gear numbers help bunches to move bigger loads.
2) Terrain - any hills along the way?
3) Trailer brakes - I am a big fan of some extra stoppers out back when towing; have had too may close calls without them.
4) How big a hurry are you in? Are you moving fast down the expressway or just putting along on a farm-market blacktop? Moving fast means more hp required, it all going thru the gear boxes out the rear end.
5) How far are you going? across a small town or across several states?
CSFJ
The factory rated capacities should be listed either on a sticker in the door jam, or if that's missing the owners manual.
lwilson77
Northern Illinois
Lee
R10
496 big block
In my experiences, the truck usually will tow more than it can stop. Get trailer brakes or go easy on the halfton.
Dons79C10
