tires/wheels ?
john55
illinois
john
My truck (C20) has 4 like new tires on it the problem is it has 16" on the front and 16.5" on the rear my question should i replace the 16 's or the 16.5 ? to have all 4 the same?
Driver4r
Nebraska
Trevor
k10,c20
i would convert to all 16"s. 16.5's are getting alot harder to get a set(resonable priced while still good performance). If i step up to 8bolt axles, Im gonna run either a set of 16's or 17's.
john55
illinois
john
i didn't want to haul 2 spares i imagine the 17's tires are quite a bit more expensive? plus new/used rims
Driver4r
Nebraska
Trevor
k10,c20
16's would be just fine. I say that i would possibly go 17's because i would be buying a full set of wheels that were 8 bolt.
You could get a set of 16's and keep 1 16.5 on you as a spare and leave 1 at home.
There are more 16" sizes available these days. You don't need to carry two spares though, as long as the OD is close between the two.
itsachevy
b.c.
jay
c20 cheyenne
350 4bbl
Go to 16 inch - the reason the 16.5's were already changed is cause the tire had a tendency to leave the rim if you got a flat which could be fatal on the front - lt 245/75/16 is the direct replacement size - just make sure they are "e" rated for load - you have low gears out back like mine - i use lt235/85/16 toyo m55 , great for hunting /snow/logging roads -
Dons79C10
