Timing Changes?
CWGRL
SOCAL
JW
V2500
I've unplugged the timing wire, set the timing to "zero" correct?
When I plug the timing wire back in, timing jumps up 12 degrees.
is this normal?
YES!!! Also engine should be warmed up setting the 0 timing. The instructions are on the vacuum label if you have one on the top of the radiator support. I think I might be forgetting one thing though.
Wooohoo!!!! This thing is alive again. Long live Suburbans!!! :grd:
We dont have any '90 Burbs with a 454 in the library yet but this might help?
attachment.php
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
It says she has a 350, but 454s are 4 degrees base timing.
CWGRL
SOCAL
JW
V2500
Thanks 89! Maybe, I'm a little OCD with this timing... LMAO
It's set at "zero" with tan/black wire unplugged. I won't worry about what it is with it plugged back in..
This Suburban will stay alive as long as I live!!! :dancingpoop:
Winner never quit, and quitter never Win!!!
Jims86
Patterson,Ca
5.7 TBI
Disconnect your battery for 15 seconds after you set the timing to clear code 42 from the ECM memory.
austinado16
Central Coast, CA
GMC V1500 Suburban SLE
5.7L TBI/4L60/3.42's
Two questions:
- What's code 42, and if you don't disco the battery after making an adjustment, will there be a problem?
-Is there any harm in advancing the timing slightly off zero, so that it's running a little more advance? As long as it doesn't ping under load...on long grades, etc......or would that be bad?
wilson79
