Tight Turn Signal
CarNut
Alabama
Hi everyone, new to the square body world. Did a quick search and didn't find my issue. My 85 Silverado has a very tight turn signal when i use the left, the right is normal and moves freely. Any suggestions to look for as I tear into the column? Thanks!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I’d make sure the stalk is seated properly, which it probably is, and I imagine it has to do with the switch itself. Hopefully someone else will chime in.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Agreed. Also might not hurt to pull out the stalk and verify that the cable that runs from the stalk isn't being pinched between the stalk and the hole in the steering column when you try to operate the left turn.
Hope that makes some sense. That cable can bind if you turn left or right and the cable isn't centered in the hole in the column that the stalk passes through.
crpntr78
Missouri
Watching this one as my '84 has the exact same issue. New switch from rockauto.
CarNut
Alabama
Thanks for the quick responses. I will take a look at the stalk and open it up to see what's going on when I get back home in a couple of weeks. I will post what I find.
MRmolash
