Mlcdc1
- Aug 19, 2016
- IN
- Matt
- C10
I have reviewed several posts on this issue and have found them to be a great value - unfortunately I still am having an issue with the 2-3 shift on my 1977 GMC heavy half 2wd pickup (1-2 shift is good). A little background- I recently finished a 1 year rebuild of the truck but did not touch the motor or tnsmission as both were working fine when I started the rebuild. I changed out the vacuum module and installed a new governor, replaced the filter and new fluid. I have unhooked the kick down cable and that made no difference. It does seem to be worse when the transmission is warmed up. Any suggestions before I breakdown and call the transmission shop?
