Sttering column bearings
Skippy969
NC
GMC
I have a 85 gmc High Sierra. I took the steering column apart to tighten up the 4 loose bolts. While taking it apart, the balls for the bearings fell out. I got the back one back in and now I'm putting the pivot pins in and the balls are falling out. I have something put in wrong and the bearing is not being held in place. Does anybody have any pictures of the order the parts go back together?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
I rubbed a finger full of high temp bearing grease on mine to help them stick in place. The plastic retainer that holds the balls doesn't retain them too well.
CalSgt
CA
Casey
Also, when placing the tilt mechanism back over the shaft be sure to pull the tilt lever full rearward so it has an easier time getting into position without being forced.
K10noob182
