Stereo Upgrade Issue!!!!! Please Help
AlecIsaacMullen
Alec
So heres my situation, its extremely frustrating because I don’t know why its not working Ive installed dozens of car stereos without issues. I installed a 5 channel amp w/ 4 speakers and sub in my 79 C20 a couple weeks ago. It sounds really nice but I was running a cord directly to my amp from my iPod or iPhone. I wasn’t getting the volume I was looking for so I decided to conceal a head unit somewhere. I didn’t want to do this originally because I want to keep the original look with the radio and did not want to buy one of the retrosound remakes. Anyway I found out the deck I had would fit perfect in the glovebox. I took the dashpad off and pulled the wire harness from the back of the stock radio, I patched into the black and yellow wires I used the black as ground and the yellow as the accessory because from what I understand the stock radio didn’t have a constant power? So I thought my issue was I didn’t have a constant power. I spliced the power to the accessory just to see if it powered on when the truck was on, I got nothing. The radio should have powered on correct? Anyway I would like to know what a good constant power to use would be, if you know the color of the wire aswell that would be awesome. PS. Ive checked the fuses in the fuse box, they aren’t blown. Also the stock radio still turns on so I know the wires have power, so unless my T claps aren’t connecting I don't see what the issue is.
yevgenievich
Place
Name
Year
Model
Size
Grab a volt meter and verify. Radio needs both non switched and switched hot wires.
silverscottsk10
trafalgar indiana
mike
Orange from the cigarette lighter is a good constant to tap
87ChevyR10
Kansas
NA
NA
NA
Before I disconnected the now faceless stereo, I found the PO had run a single wire from the stereo to the headlight spot of the fuse box. I had to keep the face unplugged to keep the radio off when the truck was off.
Johns C10 Hubcap
