Jeez you guys...
Those cone washers have a split in them. You need to clean things up enough, wire wheel on a drill, to see the split in them buggers. Then take a 1/8" punch and grind about a 15* bevel on it so you can hook one side of the split in the cone. Wacking directly on one side of the cone and the other gets them moving.
Then go wild with the bfh... Turns a 6 hr job into 20 minutes.
