Spark plug gap
86suburbanNJ609
South Jersey
Aaron
Suburban
I set my spark plugs at .45 on a 350. I see guys saying .35 am I doing any damage to truck? Should you against the chevy recommendation?
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
I used AC Delco R44T gapped at .035 per specs. When I switched to HEI distributor gapped at .045 due to the hotter coil. I had read many people state that it was ok. You are probably ok at .045, with oem distributor, may not be as efficient as .035. Just my observation of various forum members.
idahovette
Weiser Idaho
Perry
K20-K10
If I remember right when GM first came out with the HEI system they were gapping at .060. (74)? Then they went to .045
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
My 74 had oem distributor (points). I upgraded to HEI. From info that I found, GM came out with HEI beginning in 75. Did not know about .060 gap. Seems quite a bit much, IMO.
idahovette
Weiser Idaho
Perry
K20-K10
Yeah you may be right ,it might have been 75. We had a farmer who bought a new 75 C-10 454,400 a/c ps everything and had nothing but trouble with the ignition system. We put it back to a point dizzy and problem gone! Bad modules and lack of knowledge on every bodies part.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I’ve always gapped at .045
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
I always go by what the emission sticker says to gap them to. Just helped a neighbor with replacing the coil, and ignition module on his 84 GMC K-2500 yesterday afternoon. Red wire on the coil was burnt just about through from arcing. Fixed that with a new ground strap on the new coil. I like my 87's ignition better with the coil mounted on the intake manifold.
Clayton
Sent from my LG-K450 using Tapatalk
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
My complete stock 350 with an HEI ive always gapped at 35. I switched to E3 and they cannot be gapped so idk what they are now.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
How do the E3's run?. I have a set of Autolite Double Platinum's that I'm going to try.
Clayton
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Clayton
They ran alot smoother when first put in. I honestly dont see too much improvement over what i previously had. But im suspecting my distributor is bad also.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Might need a rebuild if it isn't too worn out.
Clayton
Dennis Blom
