Shifter retainer sm465
Hoodless
Willet
Chad
k20 c10
Bought a k20, trailered it home, now I see there is nothing holding the shifter in the top cover, it's just sitting there. It has an aluminum top sm 465, where can I get the retainer kit?
Thanks
Sent from my SAMSUNG-SM-N910A using Tapatalk
hirschdalechevy
norcal
rich
k-30
Bearing kit .com , you will need the two side pins as well , last time I did this I cut of drill bits and used them for the pins.
Hoodless
Willet
Chad
k20 c10
Ok, that's kit I got, says it's for the cast iron top only, but we will see I guess
hirschdalechevy
norcal
rich
k-30
Sorry I missed the aluminum top part . I have never worked with one of those late model 465's so not sure.
But here is a place that may know , midwesttrans.com
kickdeez
north carolina
kyle
Suburban 2500
454 tbi
I swapped from the cast iron top cover to the aluminum top cover, and my original shifter retainer parts worked. I think you'll be fine.
Hoodless
Willet
Chad
k20 c10
OK thanks fellas
mick84
