@#!$%$& Seized brake calipers
77 K20
Montana
K20 5" lift
HT383 fuel injected
My state here LOVES to slather on de-icer onto all the roads. Often I see those bastards out at 5 am dumping it onto dry pavement. Forecast for the day? 10% chance of light snow...
I've had 2 seize up this year so far. One rear one (yes, disc brake conversion) and now a front one. I lose typically at least one per year.
I've tried different brands from different stores. Nothing seems to matter. Lately I've been using NAPA ones just because their store is covenant.
Should I coat the hell out of the piston area with brake grease to try and seal it better?
Or should I just replace all 4 every year as a preventive thing?
Luckily I haven't been out in the middle of nowhere and had the damn thing seize up yet.... but give it time.
Any ideas?
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Lifetime warranty, and get new ones every year? We get so little snow, that when we do, the area just shuts down. I am the only one on the road during lunch on a weekday.
Few random idiots like me out during those times.
For context- this road is usually packed.
SquareRoot
It was 89 here when the sun came up this morning. How the f**k are you getting snow in July?
Arkansas_V8
Proud Redneck
Brent
V20 Suburban
LOL, it was to show 77K20 some places dont use salt, and grime. We just shut down. Like a haha kinda thing. Pic is from like Feb, or March.
Hey they would have to stop the global warming rants if that pic was taken recently. Right? Nah, liberals arent that smart. Ice caps melting causing it to snow. LOL
CSFJ
That's weird to have that many seize, and be of various brands too. Even up here in Michigan, where they dump salt and deicer the same way (I have literally seen them scraping and salting dry roads), I've only ever had one of the rotted shitboxes I've owned over the years seize a caliper (or two in this case) it was on an old jeep, and never had a problem after I replaced them. Are they actually corroding and seizing? It couldn't be contamination in the system causing it?
4WDKC
Southern Florida
Kacy
Any ideas?
snow already? I would see if any of the replacements have the phenolic pistons, that may help prevent them seizing.
77 K20
Montana
K20 5" lift
HT383 fuel injected
This is something I haven't heard of- what are phenolic pistons? I had to look up what the pistons were made of on the ones I have bought: steel.
Is there a particular brand that uses phenolic pistons?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I bought a 2014 Passat with only 20,000 miles on it 2 years ago. After going thru one winter my front right caliper seized. No it isn't just my K20 it has been all my vehicles for the last 10 years.
The system is brand new and the fluid is as clear as possible- so no corrosion.
I have a heck of a time with a huge C clamp to get the piston pushed back in- so definitely some corrosion going on.
roundhouse
atlanta ga
justin
77,78,79,80 ?
Thought Most pistons are aluminum
I’ve had a couple seize up after less than three years in Georgia
Where it was 96 and 90% humidity this afternoon
Phenolic is some kind of plastic
Never seen one
4WDKC
Southern Florida
Kacy
I have never heard of the brand but GMT400s used a phenolic piston and is what made em think of it. With the troubles you are having I would check your local lifetime warranty stores and find one that has phenolic\alum. pistons so you dont have to replace them every year and when you do they are free. Also make sure your brake fluid is new/clear as it ages it gets water in it and can make the calipers/lines rust from the inside out.
https://www.rockauto.com/en/moreinfo.php?pk=9746196&cc=1051681&jsn=1116&jsn=1116
77 K20
Montana
K20 5" lift
HT383 fuel injected
So just now finally got around to looking into this. I've been making trips from MT to Seattle for doctor appointments for my daughter. Taking up a lot of time and $$.
In fact this latest incident occurred while I was in Seattle. The wife called me and said the front wheel of the truck was smoking. Based on previous history I figured brake...
No. The spindle nuts backed off and then caused the hub to engage on the highway. Before it fully engaged it ground itself to hell. All the grease in there smells burned- hub, bearing, and spindle look ruined.
I'll open up another thread asking some related questions to this.
:banghead:
Hard
