rich weyand
- May 28, 2014
- Bloomington Indiana
- Rich
- K10
Rich a distributor is a distributor... they all do the same thing. The link you posted has a really trivial issue that I wouldn't even consider a problem. Just get some new springs and weights and tune away which I would do with any dizzy. Now if it was the issue msd had with their streetfire dizzy ignition modules and coils going bad in the middle of nowhere then ya I'd be hot...
My setup is simple. I speak of crankshaft degrees( the number your going to see with your timing gun) engine running at normal temps using the timing tab or tape I find my 8 or 10 degrees of vac advance. Same applies for total and centrifugal...
OK, so you are running 33* advance at rpm with your foot in it, and about 42 degrees at rpm in cruise. Interesting.
