Removing Door Mirror Anchors
Doppleganger
OH-MI: Just like it sounds
Is there a trick or secret midevil tool used to remove (and replace) these anchors? THX
Copymutt
Colorado
My 74 just has SM screws threaded into the skin. Reworked them today. Oversized the hole and went with stainless fine thread. Tapped the holes.
Yours look like the option is drill them out.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Yeah…. I’m pretty sure those are rivnuts.
There’s a decent tool on amazon for replacing them but to get them out they would need to be drilled or ground off.
The simple tool is a bolt with an oversized washer basically but the rivet gun type tools do such a nice job with way less work.
Astro Pneumatic Tool 1442 13"... https://www.amazon.com/dp/B003TODXQW?ref=ppx_pop_mob_ap_share
rwjtexas
Beaumont, Texas
Rob
6.2L Diesel
Those are called Jack Nuts and are 1/4-20 thread on the inside.
You should be able to use a 1/4" drill or the diameter of a 1/4" screw or so to run the inside of the Jack Nut all the way to the threads on the nut .. these work like wall anchors that the sides collapses when the screw is tighten.
use a couple of drill bits going upwards but be careful ..once the inside is drilled out with a 1/4" the walls may collapses and these can be lifted out carefully.
I bought some new ones to replace the old ones, the bottom screw goes into the inside window brace that goes to the inside door panel.
These are available on Amazon, however I bought a lot of interior screws from Turbo 6 Restoration.
Todd Lemon
