Rear end conversion
adriner
Out in the sticks, PA
Adam
k25, c20
350 nv3500, 6.2TD th400
Here's the deal I got a 14 bolt semi float rear with 4.10, 3.08s would be nicer. So my question is, can you put the 8lug axles in the 10 bolt rearend if you change the spider gears and backing plates on the axle tubes? I don't see why it wouldn't work but then again my knowledge of rear diffs is weak.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Seals and bearing are all different. Wont work
