Radiator shroud
DirtyDYT
Ohio
‘79
My one potential parts source flaked on me so I’m left needing just a shroud to finish my project truck up for its first test drive. That’s it.
Will drive to meet, just need a radiator shroud to customize for electric fans.
QBuff02
Central IL
Quincy
Did you look at lmc truck? While I was doing the engine rebuild on my truck, the shroud that was in it was scabbed together by previous owner from two shrouds that were both broken and it was still broken.. didn't want to put garbage back in so I went online to lmc truck and found the one I needed (454 engine isn't original to my truck) and ordered it and shipped to my house for less than $60 with all new j-clips and bolts if I remember correctly. Might be an avenue for you to pursue instead of driving all over to meet someone or trying to locate what you need. even doing a custom fan install, starting with new might make things easier. Just my .02
:cheers:
xXmutantXx
