Power window problems
jmill17
Nebraska
Jason
The passenger window on my truck won’t roll up. The driver’s side works fine, both up and down, and when I try to roll down the passenger window further, it makes a noise. I tried to jump the switch to make it go up and even that doesn’t work. The harness in the door and conduit looks to be in good shape as well, but I haven’t looked under the dash yet. Anyone else experience anything like this and have some advice?
Jimmyperf400
Peter
Full size gmc jimmy
Sbc 400
Buy yourself a new power window regulator and motor. Sounds like the teeth on the regulator at the point where the teeth from the motor just grind because there either missing or just worn down. Do yourself a favor go to lmc trucks order a regulator and motor and put them in and it will work. You must have power there if it makes noise.
jmill17
Nebraska
Jason
It only makes noise when going down, and more of a clicking noise than grinding. The window is stuck down. Will I be able to get the regulator and motor out with it down?
clee
