Park lights....circuit #9...help
SquareRoot
I've studied the wiring schematics till my brain hurts. I also have my instrument cluster out of my dash.
Here's what I know:
The parking lights are fed from the light switch. It's the brown 18 guage wire (circuit #9).
What I'm trying to do:
Connect my Viper alarm to flash the parking lights and tie in the cab running lights.
The issue:
Does that circuit run thru the fuse panel? I want to tie into the circuit after any fuse so it's protected but I can't figure out if that circuit has an empty port or if the circuit changes colors going thru the fuse panel.
SquareRoot
Nevermind. Found the answer on AutoZone website. They actually have some decent wiring diagrams that are a little easier to read than the OEM.
detroitamerson
