Oil Pump Primer Tool
Bobh
Houston, TX
Bobby
Thanks to some research on here, I found the oil pump primer tools. Is there a best one? I looked at Summit online last night and there are several with varying prices and a ton on ebay from $20-60. I don't want junk but I don't want to spend triple what I needed too. 1978 454 will be the first use. Thanks
yevgenievich
Place
Name
Year
Model
Size
The cheap ones should work fine if used carefully. I have used a cheap long extension ground down to the correct shape on one end with no problems. I believe the only difference on more expensive onrs is the extra guide/bushing so it can't slip when turning.
nathan27
