OEM Part Number
texasmike
Conroe Texas
I have a 1984 C10 5.0L LE9 Silverado with what I believe is an R4 A/C compressor. Can anyone tell me what was the original part number for the compressor? Thanks.
Finkaire
Finkaire
California
Loren
Silverado c10
Call your local GM dealer with the VIN for verification. I believe all the A4 compressors were the same except for the clutch assembly
chevytech87
Tomball, TX
Brandon
GMC R1500
I can have my guys look in the morning if you provide a vin, we’ve got a wholesale parts guy with an 85 K series that knows 90% of the OE numbers by heart who I’m sure could help!
texasmike
Conroe Texas
Thanks, I appreciate that. The VIN is 1GCDC14H8ES125872
texasmike
Conroe Texas
Do you know who the manufacturer is? I know Standard Motor Products (SMP) currently makes them for a number of distributors. Since the demand probably isn’t too high, I wonder if they make them for GM?
I’m on my third new compressor and like the previous two Murray’s, this ACDelco is leaking at the seal and making a shrill noise only at startup and is also slinging oil on the wheel well. The clutch pulley on all three compressors, is a little wider than the crank and PS pulleys so the 7555 Gates belt doesn’t fit properly.
Thanks for your help.
chevytech87
Tomball, TX
Brandon
GMC R1500
Unfortunately I’d probably have to have it in my hands to confirm. Allegedly it’s a real delco part, whatever that means these days. I get just as many junk parts that are “GM” in a box with a GM number as I do aftermarket. It’s pretty sad
My original A6 compressor blew the shaft seal a while back. I got a rebuild kit on ebay that had the new design double lip seal instead of the carbon/ceramic one that they originally used and it worked great. I think it was only ~$30 for the rebuild kit and you can get all the special tools to disassemble the clutch and compressor for free by renting them from autozone or oreilly.
texasmike
Conroe Texas
Who has the “real” delco part for sale?
chevytech87
Tomball, TX
Brandon
GMC R1500
