O2 Sensor
Triv
South Jersey
Joe
k10 Silverado
Put new headers on my '86 Silverado and they do not have a port for the O2 sensor. I believe this is what has been triggering my check engine light since it started when I made the switch. I trashed the sensor and the connection to the wiring harness has just been dangling ever since. Any way to stop this other than tapping into the new headers with a new O2 sensor?
yevgenievich
Place
Name
Year
Model
Size
with headers should install a heated O2 sensor.
Snoots
Roger
Jimmy Sierra
350 w/203
You could install a bung at the exhaust crossover and extend the O2 wires.
Go to the bone yard with a hacksaw and wire cutters and get the O2 sensor, the bung and connector with wires. A good welder can install it.
Just my 2 cents.
gpmorgan
Tupelo Ms.
greg
I bought a collector with the bung in it.
yevgenievich
Place
Name
Year
Model
Size
OK, class is in session. Please enlighten me on needing a heated O2 sensor with headers.
Without heated O2 the ecm will stay in open loop longer or forever if the O2 sensor never gets hot enough to operating temp. Headers often move O2 sensor further out
I think people are starting to negate this in practice, at least on this website. I thought the same, but a couple people who ran the one wire sensor with headers, and then switched to the three wire said that it didn't make any difference for them. They didn't have check engine lights before or after, and the truck didn't have any trouble getting into closed loop before. They said it ran exactly the same either way. The only logical thing that I can think of to bridge these two stances is maybe if the bung is on the collector it can heat up better, but it can't if you install it further down the line. I don't have any data to back either side up, or my hypothesis there, but the OP said he has an '86 truck. There shouldn't be an O2 sensor unless it's a CCC California truck, it's been converted to TBI, or it's an '87.
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
I have long tube headers on my 86 with a 95 big block . I had to put the o2 sensor in my passenger side collector . then had to put a heated o2 sensor in to get it out of open loop . with headers it is moved to far out and only have 1/2 the exhaust heat going over it . if you move it back to the x pipe it is even further from the engine and the heat .
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Nothing...a heater o2 sensor is a waste of time. Some people have argued that it leans out the mixture....blah...blah. I drank that Kool-aid, bought and installed and wired in the heated o2 sensor......and it did absolutely NOTHING
No open loop, no check engine light and runs fine.
yevgenievich
Place
Name
Year
Model
Size
If you do not have issue with open loop and no check engine code then there is no need for the heated o2 sensor. But if starting with not having one at all, it is a safer choice to buy a heated one vs finding out that in that particular application the single wire O2 is not good enough. In a lot of cases, installing a non heated O2 sensor far away in the collector of the long tube headers can cause problems
75gmck25
Northern Virginia
Bruce
Using a heated O2 sensor lets you install it just about anywhere in the pipe, since you don't have to worry about it getting hot enough to work properly. This is sometimes an advantage, but is not always needed.
I have a wideband digital AFR meter, with the heated sensor installed in the exhaust pipe that runs right under my foot, and it works very well. YMMV.
Bruce
Dons79C10
