Np208 stuck in 4wd
82_k10
Louisiana
Amadia
350 sbc
I believe I have a np208 it goes 2h-4h-N-4L from top to bottom. I put locking hubs in the truck. I went to test them and I locked the hubs, started backing up and turning to go in the grass and the tires were hopping like it was in 4wd but the t-case was in 2wd. So I unlocked the hubs put it in the grass and gave it gas and only rear wheels spun. I then got out locked the hubs and floored it and all tires spun (t-case is still in 2wd). I put it in 4H same thing and 4L was also fine. Also when putting it into 2h it’s almost like it doesn’t go full in gear and has more you can push it up but won’t stay. Could the linkage be bad? Thanks
boarder421
