Np208/np241 shifter linkage pics
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
So this might be a tall order for some of you guys, but I'm asking for pics of a np208 or np241 and it's linkage that leads up into your cab.
I'm working on rebuilding my s10's 4l60e, and after it's done, I'll slide her into the truck, and then proceed to setup the np241.
It's manual shift, so I have to convert from vacuum actuated to manual shift, which isn't a big deal, but I'll have to cut a hole in the floor.
I have the pieces from the 87 parts suburban to do the work, (plastic bezel, floor linkage), I just need a picture I guess of how it goes together..
Any help would be appreciated, I don't wanna cut the floor 4 times. I'd like to cut it 1 time and be done.
Thanks alot guys
sorry about quality of the shots, I wasnt taking them for the explicit purpose of helping you they were just saved. mind you these are mated to sm465 and were swapped in from a 85-86. and my crossmember is backwards and my whole assembly isnt perfectly lined up.
backlight for shifter isnt wired either. or bulb is burnt
Vbb199
Salisbury NC
Vince
That might just do, thank you!!
Dennis Blom
