Np208/np241 front output flange. *acquired*
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
In the pursuit of having actual 4x4 in my s10, I need a different transfer case. I found if I got ahold of a drivers drop gmt400 np241, it would bolt right up to the s10's 4l60e. With that np241, I can use a squarebody driveshaft which has a double cardon yoke on it, which will get me the driveline angle I need on the s10!
I found a np241 from a 1/2 ton 4x4 gmt400, but it uses a u joint yoke on the output.
I need a flat flange, like in the picture.
It may even be on a np205, but I'm not sure if spline count is the same.
But I'm pretty positive it can be had from a squarebody Chevy np208 or np241.
Thanks guys.
if mine werent in use, but here is what it looks like i guess
Vbb199
Salisbury NC
Vince
Yesssss
ajd89
Central Michigan
andrew
Pretty sure ive got one in the shed let me look after work
Vbb199
Salisbury NC
Vince
If you do, pm me, I'll send my # back and we can discuss.
Vbb199
Salisbury NC
Vince
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
@bucket
@HotRodPC
I was able to find the output yoke from @ajd89
This can be marked as sold now.
Thanks.
For future reference I found a source for a new output yoke, it was a hard search for me as well. Turns out to be a dodge flange for a 208, the sealing shaft outer diameter is slightly bigger, still works with the chevy seal though. The center pilot ring is a perfect match if I remember correct.
Misty Blue
