Np205 OIL TYPE
Uscombsp
Kentucky
Patrick
V30
What oil is recommended in Np205 backed with SM465 manual tranny? I'm putting GL-4 in tranny but not sure about T-case. Thanks for any help.
MrMarty51
Eastern Montana
Martin
You might check the specs for that transmission.
I am thinking that it is recommended for engine oil in the transmission, unless it is the newer over drive manual transmission, then it calls for a special lube with synchromesh additives in it.
Others with more experience and knowledge might chime in.
75gmck25
Northern Virginia
Bruce
The GM recommendation in my 1975 repair manual is to use SAE 80 or SAE 90 weight GL-5 gear oil in the NP-205, so 80-90W gear oil will work fine.
FYI - The NP-203 full time case recommendation is 10W-30 or 10W-40 engine oil, so it it is not the same.
Bruce
Rare Breed
