no steering
coreys87
newyork
corey
v1500
okay i ordered a new raised steering arm for a 4-6 inch lift from roughcountry but it ended up being the same as whats on my truck. so what the hell could be wrong with my front axle that it wont turn since i swapped out axles?:flipthebird:
hirschdalechevy
norcal
rich
k-30
Well tell us about your truck . how much lift , what front end , 10 bolt corp , dana 44 , dana 60 , etc...
there are three arm's for the steering , steering arm (bolt's to the axle three stud's and three nut's and three locking cone's) then there is the pitman arm (slide's on to the steering box shaft ) and then the draglink (long and has ball joint end's with one stud up and one stud down and connect's the pittman to the axle arm).
Which one do you have?
:patriot::patriot::patriot:
coreys87
newyork
corey
v1500
i believe i just got the 10bolt front end. not sure. i know its a halfton axle. and i ordered the steering arm that bolts to the axle. if im correct the draglink is suppost to be flat right? no angle from the pitman arm to the steering arm?
hirschdalechevy
norcal
rich
k-30
As far as the draglink , yes you want it to be as flat as possible , but depending on how much lift you have it may not be totally flat and it's ok if it's not totally flat , the truck just wont turn as tight and it's a little harder on the frame at the steering box. In other words the arm is for a 4 to 6" lift it will problably be totally flat with a 4" and just be a little tilted with a 6" lift which is ok. If you have more lift than a 6" lift or you just have to have the draglink totally flat you can get a 2" drop pittman arm (skyjacker) from summit racing for around a 110.00.
They also make an s shaped aftermarket draglink but it's a piece of **** ,imo.
Another thing I dont know if you have taken off steering arms from chevy's before but it can be a bitch.
Take the three nuts off and soak the crap out of the locking cones with p.b. blaster , then you have to hit downward not up to get the cones out.Put the nuts back on so when you are hitting the arm you dont hit the studs and f up the threads.
Once you see the cones sticking up a little you can grab them with channel locks and spin them off.
Remember dont hit up , hit down and on the sides
Good luck
:favorites13::favorites13::favorites13:
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Maybe you got the 10 bolt rear.:crazy:
What happens when you have the front end raised up and try to turn the steering wheel while the engine is off?
(...and pics might help)
hirschdalechevy
norcal
rich
k-30
I must have misunderstood , you can't turn it at all ?????
coreys87
newyork
corey
v1500
i can turn but not all the way to the left or to the right
Marine Corps Moderator
Do you have steering stabilizer on it? If so you might have it adjusted correct! Pics would help.
coreys87
newyork
corey
v1500
Yes it has a stabalizer with the brackets for the lift
coreys87
newyork
corey
v1500
Im thinking of ordering a block to raise it to make. The draglink flat to the steerong arm and pitman arm
coreys87
newyork
corey
v1500
Not sure whaylt you want picturez of either lol
Take pics of the front end, lift, all steering parts. Your steering stabilizer has nothing to do with the lift, it can bind and not let your tie rod move side to side
hirschdalechevy
norcal
rich
k-30
Why not just get the drop pittman arm (skyjacker) , easier to install than a block ,
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
And legal too... Lift blocks on any steer axle are illegal in all 50 states, not to mention a stupid decision.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
I dont think he means lift blocks in the leaf springs it a lift block for the steeringon the knuckle which is legal.
Try unhooking the steering stabilizer and then see if itll steer all the way both directions. Might be its limiting the travel
Gurn
