No Gauge Lights
michaelrpadgett
texas
Michael
c-10
I have an 84 c10 I am having trouble getting the dash gauge light to work... New Light switch, Light checked the circuit in back and working, trace ground down and grounded good and all new bulbs. any other ideas? Thanks!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I'm just taking a guess but, maybe the bulb contact to the circuit board on back of cluster?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Do any of the dash lamps work? The one in the stereo (assuming it’s a factory radio with dash backlighting)
Do you have power at the dash lamp fuse? I think it’s a 5 amp, it will show power only with the park/headlamps on. Make sure the dimmer is turned up.
If you have no power at the dash lamp fuse, make sure the taillight fuse is good. Make sure the taillight/parking lamps themselves work. No taillight/parking lamp, no dash lights. The taillight circuit supplies power to the dash light fuse, that’s done as kinda of warning tip.
I think the dash lamps are powered by a green wire coming out of the headlight switch. If you have no power there, but the taillights work, replace the headlight switch.
C20NamedWaylon109
