no gas to engine
cris.
dallas
cristian
Hey guys im new here wanted to know if yall could help my c10 will not run it will turn on only if i put gas in the carburetor, has a new fuel pump. And i also bought a new gas tank switch but still didn't fix the problem. You guys know what could be wrong? 350 engine
kdo58
Puyallup wa.
k5
i would replace all the old rubber fuel hoses from front to back, and install a really large fuel filter near the tank,
Skweegle89
Oklahoma
Check your hard lines along the frame for cracks. A lot of time they will crack and you will suck air.
350runner
tx
Ceasar
fuel filter after the pump. as stated check the fuel lines from the tank in forward. also if you are using a q jet check the filter inside the carb
gpmorgan
Tupelo Ms.
greg
Set a gas jug under the fuel pump and put the suction hose from the pump in it and see if it starts. If it does, do as mentioned above.
86_chev
