new truck new problem
csanderlin
ws ,nc
chris
idk
i just looking at a 76 k10 with a 400 well owners is saying the engine needs cylinder number 4 need oil ring replaces that it is makeing oil fouling out plugs i was wondering how big is it to replace. first time with older v8
hinkv10
ct
craig
v10
Its a big job. If it was a bad valve guide you could pull the head while the engine is still in the truck and have the head rebuilt. Since it is a lower end problem you are most likely going to rebuild the engine. You need to do compression checks to see if all the cylinders including #4 have good compression.
It sounds like you don't have a lot of experience so to answer your question you are going to have to pull the engine.
csanderlin
ws ,nc
chris
idk
i have done 4 engine swaps with different jeeps i bought and flipped but this first messing with v8 would it be easyer to just find a good 350 put in place of 400
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Do some research.... Dig into it and find out what's wrong with it for yourself. It's always best to assume that the previous owner is a total moron. Could be just the oil drain holes I'm the heads gunked up, causing oil to back up in the valve cover, then getting into the cylinder from a worn valve guide. Pull the valve covers, and put a leakdown tester on it, that will tell you right where your problem is.
r.booser
Knoxville
Ron
never believe previous owners. I have learned that mistake with vehicles in the past. Always check for yourself and find the route of the problem.
Charkmapman
