Motor problems
87silveradok20
Ohio
Levi
Silverado k20
So today I took my truck out for a drive and all the sudden I looked back and saw a huge cloud of white smoke. I got stopped to check it out and there was oil everywhere. The motor made no unusual noises and drove the same as it did before all this happens. The truck backfires like crazy now. What would cause all this? The truck still starts up. I am sure it was oil and not trans fluid as well. The motor is stick except for headers and dual exhaust. Has about 186k miles.
Oldrider
NC
k2500
White smoke indicates you are getting water into the combustion chambers. Maybe blown head gasket.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Is the smoke oil burning off the exhaust or coming from the exhaust?
87silveradok20
Ohio
Levi
Silverado k20
That would make sense. The oil is over full and there isn't any coolant.
87silveradok20
Ohio
Levi
Silverado k20
I'm not sure but I'm thinking a combination of both.
87silveradok20
Ohio
Levi
Silverado k20
It does look like there's excess fluid coming from between the block and head.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
IDE say head gasket then that will give you both external burning and threw the exhaust pull that plug it's probably all wet.
87silveradok20
Ohio
Levi
Silverado k20
Well it looks like that's the culprit. Is there anything I can do to these heads to get more power while it's apart?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Rebuild them, voted swap or I got a set of World heads I would give you a good deal on. Not trolling just letting you know I have them on CL locally but I'd rather see them go on something worth while. They ar S/R 1-052 1.94 intake with 76cc chambers google them and if there is interest we can talk.
4WDKC
Southern Florida
Kacy
Guessing they are stock heads? The TPI and vortec heads are better along with just about every aftermarket head out there, so you need to figure out what your budget is and your goal for the swap.
mick84
