Mirrors
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
Right now I have these tripod mirrors and I don't like the way they look.
These mirrors that I see on most square bodies are the ones that I wanted from the start.
SOURCE: http://images.canadianlisted.com/nlarge/1973-87-chevy-gmc1-2-3-4-1-ton-truck-mirrors_4995730.jpg
I can weld the three holes shut on the door from the tripod mirrors, but is there measurements or a template of some sort to know where you drill the new holes for the newer mirrors? I know it can be done but I don't how people do that. Any help is appreciated.
Great choice, lol!!! :High 5:
I can measure mine up if nobody beats me to it, I will check later.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
Sounds good! You don't have to rush to it if you don't want to i'm FAR from putting these mirrors on.
I found out there's another option for mirrors out there. I went and looked at a truck today that originally had the little sport mirrors, but somebody put on some aftermarket stainless mirrors that look like the dumbos, but smaller. They were basically 3/4 scale dumbos.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
Did those even look alright on the truck?
WestCoaster
Ca.
Bart
Just use a piece of paper as a template, put up on door, mark holes and drill.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Might have been Dodge mirrors.
RetroC10Sport
Jay
pontiac aztek
They're aftermarket, squares didn't get the common dumbo style until 1980.
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
I can easily make a template but I wanted to know where to slap down the holes on the door.
Here's pics and measurements from mine, these are factory size and location. I also believe there is a brace/reinforcement on the inside of the door skin, you may want to make sure you do that:
Thank you very much, this will help out a lot
QUOTE]
I guess they dont look that bad. I still like the regular size better though.
I know they're aftermarket, but then you threw Dodge into the mix...
RetroC10Sport
Jay
pontiac aztek
Yeah, they were available in stainless too.
I was going to use a set in black with black Chevy bases because some of the black ones (as well as stainless) were power.
82SquareBurb
