m55hv pump in stock pan - what oil pickup?
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Trucks got the stock 7.25" oil pan. Installing a new Melling m55hv high volume pump that is slightly taller than the stock pump.
Trying to determine what pickup will work. Looks like I need one that has a 5/8" tube diameter, and has only a 3/4" drop between the tube centerline and the bottom of the pickup due to an "optimum" 3/8" clearance between the bottom of the pickup and the pan.
Thinking I can order a pickup designed for a 7" pan being that the pump outlet sits 3/8" lower on the HV pump versus the stock pump. So that would let the pickup sit around 1/8" lower than previously, but this is all calculated out before the oil gasket has been installed.
Sound about right?
yevgenievich
Place
Name
Year
Model
Size
Sounds like it should work. Maybe bend a little(1/8) as well if needed
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Seems like we're in similar stages with our engine builds - I'm working on oil pump issues now too. So which pickup are you going to end up using? Melling 55S1? Seems like it will work pretty good with my Melling M55 pump and stock pan.
How are you securing the pickup to the pump? Weld? There is a bolt on pickup retainer available for $20 or so, tempting but I might try welding first. I have the original pump and pickup that I can practice on. If I don't like it I may buy the retainer.
yevgenievich
Place
Name
Year
Model
Size
I welded a pick up tube out of emt condoit before for a 5.3 in a datsun. Seem to work ok
74 Shortbed
Be very careful welding/brazing it's very easy to warp the body, if it does warp the relief valve won't work, and I've seen a lot of welded ones crack too, I use green Loc-Tite(bearing race retainer)it'll never fall out, and you can always safety wire it if it worries you.. Just my experience over the years, do whatever gives you peace of mind..
MikeB
Melling says to use their 55-S1 pickup/screen and IS-55E intermediate shaft with the M55HV pump. The screen can be adjusted up/down for proper pan clearance before you tack weld it. Just stick some clay or play dough at the bottom of the pan, tighten a few pan bolts with gasket in place, and go from there.
After Melling reduced the weight (made it less stout) of the M55 series pump several years ago, I switched to Melling Select 10552. More expensive, but nice features and cheap insurance. And your engine probably doesn't need anything more than its 10% additional volume.
http://www.melling.com/aftermarket/high-performance/cast-iron-aluminum-oil-pumps
https://www.summitracing.com/parts/mel-10552
Daveo91Burb
Vancouver, WA
Dave
I bought the green stuff today (it's actually Permatex brand, but they use the same color coding). Used that AND I drilled and tapped a hole in the pump body where the pickup tube goes in for a 10-24 set screw. Put that one in with RED loctite. No welding. Should be good to go.
So I actually found out that I'm just using a regular M55, not the HV. My engine builder recommended a stock pump for my build. I'm sure I could do better than the 55, but it's a good price, seems decently well made and in the USA to boot. I think I've been running one in my Vette for the last six years and no issues so far.
74 Shortbed
It ain't going anywhere now..
You can only push so much oil through the passages. There's absolutely no reason to use a HV pump unless you're feeding accessories like turbos and ****, all it does is take power and put stress on the distributor gear, what needs to be done to a stock pump or any of them for that matter is reduce the gear to cover clearance, they have way too much clearance in them as they come, set the clearance and you'll think you have a HV pump, and if you still want more pressure an AN washer against the spring will step it up 5lbs or so..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
You can only push so much oil through the passages. There's absolutely no reason to use a HV pump unless you're feeding accessories like turbos and ****.
Just curious what other "****" are we gonna run with the oil pump????:emotions33::think::happy175:
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Does a HV actually use more power to spin? I thought that was more in line with HP pumps?
On the mighty cast iron BBC, you can port the rear cap to help flow. I don't know if this is relative to the sbc.
As we know the BBC can be hard on cam lobes. So we cut a groove on the lifter bore to get more oil on the lobes.
Would this mod benefit with a HV pump?
Also enlarging (sorry forget the specs) the plug hole above the cam chain helps the lifespan of the timing chain,
again flowing more oil than a stock engine.
MrMarty51
Eastern Montana
Martin
I have rebuilt a few engines in My time and have just drove the pickup tube into the pump, none of them have ever shifted or fallen off.
74 Shortbed
If you use a speed handle to prime the motor by hand, you will feel the difference between the two and it's very noticeable.
Right, I do it all the time big or small block, but all that does is smooth out the flow and eliminates turbulence at the pump, passages are still the same size as bearing clearances, so the volume is still the same.
Well, that depends on how deep of groove you cut, lol, just the slightest bit will flow enough oil without affecting the volume, also if you clean out the center slots in the valley helps too.
The two galley plugs are already drilled .035 from the factory to release air and to lube the chain, any bigger and the oil gets whipped around and gets aerated, not the best thing. As I mentioned before, set the clearance right (.0025) it makes the pump more positive which will flow more oil and an increase in pressure.
Dennis Blom
