Left turn signal not working
jkhll8
Kentucky
Keith
1987 R10 2WD shortbox
R10
5.0 TBI
I had the big idea to change my bulbs to LED’s. Changed the left rear and the turn signal wouldn’t work. So I changed them back and still nothing. Any ideas before I tear into it?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Check for a bad bulb socket with a multi-meter. Over time the contacts get loose. Pull the hazard switch, then check the turn sigal contacts for voltage...btw...led bulbs are picky when it comes to which way they install in the socket
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Diodes are gateways that only let voltage flow in one direction.
jkhll8
Kentucky
Keith
R10
5.0 TBI
Ok thanks guys. What’s the best led bulbs to go with on the rear?
smoothandlow84
Steve
I just filled in my rear housings with strips of white led lights, wiring them in series, the bulbs available on the market are useless. I purchased a roll of 12 volt led strip lights off ebay $8 for approximately 5 feet). There are 6 leds per section (they have lines that indicate how often they can be cut). I attached the strips to the inside of the housing in rows...wallah, brighter lights and cheap at that.
If you can solder, it's quite easy.
There is also a website called "super bright leds", and they carry all sorts of leds as well
Crispy
Carbon County, Pennsyltucky
Suburban V1500
LEDs draw much less than incandescent bulbs and need an LED flasher to be installed in order to flash properly. As for the brightest bulb, its hard to say since there are a million companies making them. Try to find one with the most SMDs. Something like the pic below
They have other styles that only have forward facing diodes that will not help your cause. Stay away from these:
Finally, you need to match the color of the led to the color of the lens it will be behind for best results. Amber LED behind amber, red led behind red.
jkhll8
Kentucky
Keith
R10
5.0 TBI
Nice, thanks!
Layne02
Ga
Jeff
R1500
Hi, curious if you figured out why left signal not working, mine has same problem.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cleaned it with 90% isopropyl alcohol and stuck it on. I have a **** load left lol
wilson79
