leaking speedometer gearing port in tranny help
Joseph_siller
Anaheim
Joseph
hello everyone Im looking for some different opinions on what to do when switching over to gps gauges and leaving the old speedo gearing in tranny. mine leaks and I'm switching over the gps gauges so what is it that some of you guys do to delete that hole in the tranny since it is no longer needed do you just leave the old gear in there or does someone make a delete plate for it please help I'm lost!
gpmorgan
Tupelo Ms.
greg
On my th400, I just left the gears in it and the cable unhooked. I've got to find an elec adapter but for now it's just unhooked.
Joseph_siller
Anaheim
Joseph
so do you still need that gearing and all that even though I'm switching over to electronic gauges?
gpmorgan
Tupelo Ms.
greg
I have a 92 and it's got an elec speedometer so I need an adapter for mine. If you're going to elec speedometer, you will probably need one to. I've found a few at summit but not sure which one I need. You can change out the speedo gears and install a reluctor wheel and sensor on some transmissions . It would probably cost more. If you're doing aftermarket they will know which adapter you need.
Camar068
Kentucky
10 yrs Air Force
replace the o-ring to fix the leak on your current setup.
