Lap belt to Shoulder belt conversion
SlickGTP
Houston, TX
Has anyone in here put shoulder belts into an early Square that had only lap belts from the factory... I'm curious to know if it's a bolt in or if there's more to it than that.
Thinking this would be a nice and worthy upgrade for the ol' girl so I don't end up smashing my face into the steering wheel should the unthinkable happen.
Is there a hole with a plug in it, up in the pillar?
SlickGTP
Houston, TX
Just pulled the trim off and yup... Let me guess... there's mounting nut behind it?
Sometimes. If not, I think you can fish a nut up in there an give it a couple good tacks with a good welder. The stiffener plate is hopefully there even if the nut isn't.
SlickGTP
Houston, TX
Thanks! I finally got in there and pulled the trim piece all the way out. Plug twisted out easily enough and behold... A mounting nut for the shoulder harness.
Now I just have to decide if I want to drill holes in my existing trim or buy new trim pieces...
FenderBanger
