k20 350 Fuel problem over 40?
Project_82k20
maine
luke
k20
I just bought an 82 k20 with a 350 in it. The guy said that it just needed an electric fuel pump to help the mechanical one. I knew that the mechanical one was fine and just figured it was something with the carb. However i cannot seem to figure it out. Anything over 40 or when you step on it it sputters and seems to be getting not enough fuel. Any suggestions? thanks
4WDKC
Southern Florida
Kacy
floats adjusted correctly? checked the spark plugs for carbon build up from being to rich? check timing? did you rebuild the carb recently? Checked fuel pressure mech. pump might be week.
WFO
Texas Panhandle
Float, filter, or clogged fuel supply.
All these things and it could be the fuel pump or cam lobe that operates the fuel pump and it's not getting enough volume to keep at 40. You could get one of those clear plastic fuel filers and hook it inline to where you can see the fuel volume it's pumping.
rpcraft
Robert
LS 6.0 364 CID
I'd probably look to add a clear filter but also replace the fuel pump. They are cheap to replace, not too terribly hard (if you have swapped to flexible lines) and they don't last forever. If the diaphragm is getting cracks and leaks it just starts having issues metering out the proper volume at higher engine speeds.
I'd agree, but first off we'd need to determine if it's the fuel pump or the cam lobe. I've seen where cam lobes get wore down and they don't work the actuator arm very good and even a new pump can't keep up. It's not extremely common, but it somewhat common for the fuel pump cam lobe to get wiped out. The seller might know something we don't and why he suggested it needed an Electric Fuel pump.
rpcraft
Robert
LS 6.0 364 CID
That is a good thought. I know it's not common but it's definitely a pre-cursor to when things go wrong, like low oil pressure or low oil level.
Project_82k20
maine
luke
k20
Thanks for all the feedback! Rebuilt the carb and replaced all the fuel lines and it looks like that did the trick!
  • Like
Reactions: WFO
musiq_lee
